RCU Forums - View Single Post - CAN ANYONE HELP ME ??
Old 08-23-2007 | 02:15 PM
MBUTLER1967
Default CAN ANYONE HELP ME ??
I have a Sundowner Formula 1 Airplane with a 9C SUPER PCM Radio by FUTABA. My reciever is a R319dps PCM 1024 by FUTABA. On the reciever its showing slot numbers 1 through 8 then it has a slot called 9/B and then it has a slot that says DSC. I have 6 servos on the Sundowner which are high torque servos also by futaba, anyways my question is how does this all go into my reciever ? Example: I have two elevator servos, two aileron servos, one rudder and one throttle servo. The instructions tell me to put the aileron servo into slot 1 on my reciever ( but I have two aileron servos ) then it says put the elevator servo into slot 2
( again I have two elevator servos ) I know where the throttle goes slot 3 and the rudder in slot 4. The instructions says slot 5 would be landing gear ( but I dont have landing gear ) slot 6 the intructions says is FLAPS/2nd FLAPERON, then slot 7 is AIL. DIFF, whatever that is, and 8 is Auxiliary channel. It also says that the battery can be plugged into an unusual slot such as 7 or even plugged into a y-harness with any servo if all 8 slots are in use. CAN ANYONE HELP ME. This is my second plane I have ever put together as a ARF. My first was the ALPHA 40 TRAINER which already had servos and reciever installed when I got it.
