RCU Forums - View Single Post - Diff fluids Just the basics
Old 08-23-2007 | 06:33 PM
Chubbysdad
Default Diff fluids Just the basics
I found this and thought it would be helpful for some people on changing out the diff fluids and what thick and thin does.
Front
Thinner :
increases steering into corners (off-power)
if oil is too thin the steering may become inconsistent, especially it can lose forward traction (and steering) during acceleration out of corners
Thicker:
increases stability into corners during braking
increases steering on-power at corner exit
Center
Thinner:
front wheels unload more during acceleration
decreases on-power steering (reduces oversteer)
easier to drive on rough tracks
if a high-power engine is used you could waste too much power and sometime “cook” the oil in the center diff erential because it “overloads”
Thicker:
more all-wheel drive effect
better acceleration
increases on-power steering (reduces understeer)
better suited on high-bite, smooth tracks
car can be more nervous to drive especially if a high power engine is used - you might need to be smooth on the throttle
Rear
Thinner:
increases cornering traction
Thicker:
decreases rear traction while cornering
reduces wheelspin
