RCU Forums - View Single Post - super vee guys-- help!
Old 08-24-2007 | 06:26 AM
SV27dayton's Avatar
SV27dayton
Default RE: super vee guys-- help!
If you are hearing a constant beep I believe your trim is still off. I had an issue where the plug in the reciever wasn't tight and caused the same thing. If I remember correctly you should hear one beep. Then pull to full throttle and hear, it's either 3 or 4 rapid beeps to indicate it's armed. Sounded like you were close.
