RCU Forums - View Single Post - Prop placement 2 o'clock
Old 08-24-2007 | 07:58 AM
HighPlains
Default RE: Prop placement 2 o'clock
The theory is that you put the heavy blade of the unbalanced prop on the same positon as the crankshaft counter-balance. Then the engine runs smoother, and you don't have to balance the prop. Very useful when using wood props that may not have a constant density.
