RCU Forums - View Single Post - Flying time on a receiver battery.
Old 08-24-2007 | 09:06 AM
-pkh-'s Avatar
-pkh-
Default RE: Flying time on a receiver battery.
ORIGINAL: Shortymet55
The only problem i find with my voltmeter is its not precise. Once the battery goes down a bit it starts lighting two or three lights. So when i wiggle the servos a green light could be on and so could a orange. I dont know what this means. Does anyone elses do this?
But I still like having some idea baout my battery level/
P.S. its a voltwatch2 like -pkh- posted a picture of.
I've never had a Voltwatch light up more than one light at a time with no servos moving or loaded. You can have multiple lights flash and appear to be lit at the same time when you have a loaded servo, or when you move the servos around... this is because the Voltwatch is displaying the varying voltage values as the loading on the battery pack changes.
My conditions for another flight are the no load (single light on) case should show it is in the safe region, AND when I move all the servos, the average or middle of the light range that lights up must be in the safe range.
