ORIGINAL: *JCB*
I'm going to start building an Ultra Sport 40 in a couple of days. I am planning on trying wood glue instead of CA. I will be using TiteBond2 and had a few questions:
What type of applicators should i use? Since this stuff is WAY thicker than any CA glue, I feel that application may be one of my biggest problems.
I like to put the glue in a small applicator bottle like one that CA comes in but it is not critical. I have dispensed it directly from the bottle that it came in being careful not to get too much. Even that is not critical. I keep a damp paper towel handy to wipe away the excess.
Do i need to use clamping pressure? (like when the tail surfaces are being assembled)
You only need enough pressure to hold the parts to they don't move while the glue sets. Excessive clamping force is not required.
how long should i let the glue set up for before moving to the next step?
Aliphatic resin sets in about fully 24 hours but I usually give it about an hour to set before removing the clamps. I try to plan my builds so that I am working on more than one component at a time so that I can continue the build while allowing adequate time for the glue to set.
This will be by third kit build. I used CA glue on the first two kits without any major problems (except for the fumes and sanding issues), but have read about how "once you go alphatic, you never go back," so i thought i would give it a try.
I used CA to build one wing of a biplane and went back to aliphatic resin. I will never use CA again except for tacking parts together or for field repairs.
