DX7 and AR7000 won't bind
I won a DX7 radio at one of the local Jet Fly ins, installed the receiver in a 4*120 with a Fuji 24 Gas. I was having a lot of trouble with interference with an Airtronicks set up before and just knew the Spectrum would solve that problem. Anyway, I installed the receiver in the plane spread the two receivers apart per directions, plugged everything in, all charged up and ready to go. When I turned the power on to the receiver with the bind plug in both LED's flashed once and went out. When I turn the power off and back on the LEDs will flash on and back off and that is all. I went ahead and went through with the bind process but it doesn't work. Any suggestions or do I have to send it, the receiver, back to Horizon? Like I said I won this in a raffel and do not have a receipt, what would I need from the LHS to show ownership for warenty purposes??
Thanks for your help
Gary
P.S. I have already ordered a new DS7000 from Horizon for another plane and will try it when it comes in.
