RE: MPi Switch question???
NCIS--
I tried to scan and post the instructions but they were so small you could not read them. Here are operation instructions:
"To test the battery, move all sticks simultaneously and observe the LED. If the yellow or red LEDs begin to flicker, it is time to recharce the Rx pack."
I presume you need to move the sticks to put a load on the Battery Checker circuit -- I suspect if you do not move the sticks you could get a false green. You may have already known about this but I am posting just in case.
