RCU Forums - View Single Post - Flap servo problems
Old 08-25-2007 | 10:56 PM
gosk8ing
Default Flap servo problems
Hey,
Just assembling my first plane with proper flaps and am having a bit of travel. The flaps require two servos, one in each side of the wing, joined together by a y-lead. When i lower the flaps, they go like ailerons, one up, one down. I can't really rotate the servo around 180 because of the design.
What happens if, on one servo, i change the positive and negative wires around on the servo lead? Does is work like a normal brushed motor, ie. it will rotate the opposite way??
Any help will be great!!
