RCU Forums - View Single Post - C. A. P. DAUNTLESS
Old 08-26-2007 | 11:29 AM
marwen1's Avatar
marwen1
Default RE: C. A. P. DAUNTLESS
whiterook
Here's a thought that WILL help you immeasurably!
Take your SCROLL SAW, drill 4 holes in it so you can mount it UPSIDE DOWN underneath a work table. It's a little awkward perhaps to turn the trigger swich on/off but the machine is solid and your work is flexible. Drill a 1.5" hole in your worktable, line up the blade thru it and mark your placement for the mounting screws. If they come thru the top of the table simpy break them off and sand the working area smooth.
If you use DRYWALL SCREWS, they'll hold fine, but they are very brittle. Consequently, your ability the simply break off the excess. Don't go overkill and use BOLTS. The drywayy screws will hold 100%.
Now all you have to do is BRING YOUR WORK to the cutting blade.
Remember this: "IF IT'S TOO SMALL TO BRING THE TOOL TO THE WORK -- BRING THE WORK TO THE TOOL"
Bon Chance
marwen1
