RCU Forums - View Single Post - bleeding shocks?
Old 08-26-2007 | 05:59 PM
Foxy's Avatar
Foxy
Default RE: bleeding shocks?
Different methods for the shocks of different companies, but the process is the same in principal. When you build your shocks and tighten the cap on, without the spring on the shock, compress the shock fully. Now release it. Does the shaft pop back out again on its own?? If so, then they need to be bled, refer to manufactureers guide. Which shocks are we talking about?
