RCU Forums - View Single Post -
Thread:
Old 03-17-2003 | 04:10 AM
epc's Avatar
epc
My Feedback: (33)
mpj 220:
I have the same engine so I think I can help you a litle bit.
1- 50:1 any good 2 stroke engine Amsoil , red line ( I'm using Motul racing on mine )
2-That will depend on the batt. capacity I think you should use at least a 1000 mah. 4.8 batt. pack.
3.Very easy to start hand flip , For the choke you can use a servo if you want but it is not necessary just use a piece of wire and do it manually.
4-20x10 is a good prop the one that I found to be the best for this engine is the Menz S 20x10.( Also the mejzlik 20x10 )
5- Yeah two needles The one with the H beig the high and the other one L low setting. H 1 1/2 and L 3/4-1 more or less depends on your weather and altitude.
6-Tru turn , Dave Brown. ( I like the tru turn and they sell it alredy drilled for 3w engines if you want ).
Hope this helps.
epc.
