RCU Forums - View Single Post - AK-Models Extra 300S Build Question
Old 08-26-2007 | 10:08 PM
fellers's Avatar
fellers
Default AK-Models Extra 300S Build Question
AK- Models Aero Works 60 sized Extra 300S. 63" wingspan.
Putting a OS .91 max in it.
Reinforced the firewall with 30 min epoxy and triangular stock. Also reinforced a few other spots accordingly.
I just epoxied the wing halves together and I am wondering where to cut the covering and adhere the reinforcement wood plate. Do I put it on the top of the wing? That is the only place it will sit flush. The dieheydral of the wing does not allow it to sit flush on the bottom of the wing. Also I have a cover to glue to the bottom of the wing to make everything flush and smooth on the bottom of the plane. Epoxy or CA glue for that? I then have one last question of what to use to fix the wing to the main fuselage. There is blind nuts in there now and they directions call for a 4x40 screw with a 8mm washer. That does not seem like a good way to do it to me...
Anyone build this plane yet I would appreciate your help.
