RCU Forums - View Single Post - Multiple problems with Monsoon
Old 08-27-2007 | 05:09 AM
Chubbysdad
Default RE: Multiple problems with Monsoon
First of all you should go over the machine first. The exhaust bracket needs to be bent. It is way to close to the tank. That was posted in the monsoon thread. Also, the servo saver up front is too tight from the factory in my opinion. Thats why you went through another servo. Loosen it up a bit. Just change out the piston and sleeve and once redcat has the new clutchbells, you will be good to go.We have been beating the snot out of mine, and its been doing good. Its even holding up to the jumping.
