RE: H9 ultrastick 60 using quad flaps
No sweat! Just be sure to make the appropriate changes with the servo leads at the receiver as I believe they are different from what the FAQ dictates.. The only thing that you are going to loose with the glider setup is the preprogrammed "throttle cut" feature.. But if you want that you can just program the same switch to do the same thing.. It really is crazy the way that they have the faq setup with all of the extra "p-mixes" to get this thing to work.. I don't think I had to use any p.mixes at all to get all features operating under glider (which frees up the pmixes for other stuff!).. Also, I don't have any lag at all with the aileron flaps when they are coupled up.. Not sure why that happens (did you use a curve mix for this in the acro mode?) If you still have probs after you switch into glider mode I'll send you a copy of all settings that I have and you could try that!
Anyway, curious to hear what your opinion is.. please let us know how it works!
John..
