RCU Forums - View Single Post - Extreme composite Pro-Line
Old 08-27-2007 | 11:13 AM
riot3d
Default RE: Extreme composite Pro-Line
ORIGINAL: ROGUE ROVER
OMG really[sm=what_smile.gif] when did this crash occur?? This leads me to ask about radios? I know Akiba uses / used to use a 9ZAP so i wonder what happened? is their or will their be a trend you think for pattern flyers to move over to the new 2.4 Ghz systems? ( bearing in mind as far as i am aware their is now failsafe settings only hold according to spectrum, transmissions done on PPM not PCM )
Are you happy with the model and the way it flies? What setup are using motor / radio ? do you use on board glow?
If you have any pictures of your model / setup i would love to see them.
Scot
Akiba uses the 14MZ, he works for Futaba. I guess he wasn't using their 2.4 system, otherwise, probably could have avoided the crash.
