RCU Forums - View Single Post - axe cp thread
Old 08-27-2007 | 07:52 PM
  #1504
K94max
Default RE: axe cp thread
Markind, I believe I read that you are using a Spektrum DX7 radio now? If so, and if you do not mind, could you give me a list of your settings. You see, I have just placed my order for the DX7 and I am going to run the AR6100 in the Axe. Just kind of curious as to what your settings are and possibly any advice / tips you have found in setting your system up with the Axe.
I am running stock with the motor modification on heat sink, ceramic bearings on the main shaft and I did the water break-in on the motor. (Hobbico sent me a new bird after mine started doing the kangaroo glitching . Plastic blades for the mains.
Appreciate it.
