RE: Difficulty getting new motor started.
If the engine fires and then quits, it's likely not getting fuel. You'll have to see why. The needles could be too lean, there could be restrictions in the fuel system, air leaks in the fuel system, and so on. If the engine will fire, though, then it will run if you can get fuel to it. Likely, you're getting it primed and then it's burning off the prime.
