RE: Newbie needs help!
Gdel............ I am also new to RC planks and found that going with something above my abilitys has just cost me money and down time. Not familiar with your planes setup but have you checked the Center of Gravity on your plane to make sure its perfect? Also elevator and rudder perfectly straight? Ailerons if it has it must be good too. Basically from what I have been told and read here in these forums and at my LHS is that you should be able to toss your plane gently and it should glide straight and level to the ground and not nose dive or nose up and stall. I am learning and will be better equipped for my second flight on my GWS E Starter after I rebuild it. You are not alone! Its really hard to learn to setup a airplane if you have no experience. Good luck and i hope someone like Time Pilot or crash crash answers this thread......they have some great knowledge (as well as many others........ I forget names easily) and offer sound advice!
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
