RE: 10 ft PC6 Turbo Porter
Worked alittle on the engine cooling baffles. Used two part expanding foam to fill the area between the two balsa pieces. You can tell which side was the first go round and which was the second. Need to smooth it all out and will do a light fiberglass (1.4oz) cover over it all. Extended the top of the scoop with 1/64 ply and will fiberglass it in as well.
