RCU Forums - View Single Post - O.S. engine issue
Old 08-28-2007 | 09:16 PM
jetmech05
Default RE: O.S. engine issue
since your using the term engine scream..I'll bet it was running too lean. When you tightened the head was the head hot? Did you use a cross torque pattern to tighten the screws? Or did you just go in a circle?...I wonder if the head is warpped and not seating properly
