RCU Forums - View Single Post - 50cc Sukhette Build Thread, now in progress!!
Old 08-29-2007 | 09:59 AM
  #406
ccmahal
Default RE: 50cc Sukhette Build Thread, now in progress!!
Pat Roy, mstroh3961, rxfish
Thanks for the input fellas. I don't have the alignment problem that Pat discribes with his. The slots in the side are large enough front and back. The left gear mounts with the inboard hole and the forward hole, the back is not drilled to accept a 10-32 and is off half the hole. The right gear leg mounts with the inboard hole and neither the forward or back hole will align. The back hole is smaller than all the rest. I was hoping that the angle backets were easily removed but mine won't budge. I removed the screws in the right wing well and applied some light prying pressure with a screw driver. Only succeeded in marring the wood. Still thinkin' on it!
