RCU Forums - View Single Post - Engine for rc pulling tractor
Old 08-29-2007 | 11:53 AM
pe reivers
Default RE: Engine for rc pulling tractor
The newest 116 is 327mm over the widest dimension of the standard plug caps. Still too wide I suppose?
What if you can slice off 10 mm each side from the caps by eliminating the caps and make a direct plug connection without the caps? You get rid of 20mm that way.
Powerwise, the MVVS cannot be beat in it,s class
