Receiver antenna routing
Well, I've found a new way to pull that pesky rx antenna through a tube in the fuse. The tube I used is the excess outer tube from a set of sullivan gold-n-rod control rods. Once it was time to run the antenna through the tube I just slipped a piece of the inner part of the gold-n-rod through the tube and then insert the end of the antenna inside the whole that the threaded stud goes into. Put a couple drops of CA in there and that sucker comes through quicker than anything. This is definitely how I'm going to do these from now on. Just thought I'd send out my little hint.
