RCU Forums - View Single Post - First speed plane
Old 08-29-2007 | 07:37 PM
  #38
freakingfast
Default RE: First speed plane
Bob is 100% correct, glue the tank cover down! Also, don't slam a spinning electric starter on to the motor, is the starter cone well centered? If your starter motor is too weak, turn the prop off compression(watch your fingers,use the spinner) than trigger the starter's switch. Try to spin it a few times with no power to the glow plug. Make sure it's not hydro locked. If not, get a bigger starter.
