RE: Engine running backwards! HELP
No problem Brother. Be happy to help anytime. Now lean that motor out a little at a time so you will have power but also have a good consistant idle at the same time. Check the engine temp after each flight. I usually hold a finger on a backplate screw. If I can hold it there a few seconds then the motor is fine.
JIM
