RCU Forums - View Single Post - Wild Hare 29% Sukhoi Build
Old 08-30-2007 | 05:46 AM
  #70
pupmeister's Avatar
pupmeister
Default RE: Wild Hare 29% Sukhoi Build
ORIGINAL: rxfish
I just finished up the baffling and prop balancing. All left to do now is connect control surfaces and program servos. I've mounted the horizontal stabs in front position. Hope to maiden this weekend. Will report on how the front position performs then.
Was the baffling that you installed for the motor? is it necessary if you are running a DA50 and if so can you show some pictures of the baffling?
Pupmeister
also
ORIGINAL: tomriddle
A couple more...very impressive design in the airframe...lots of mutually supporting parts...held up pretty well to my abuse...many interlocking, lightweight frame members.
I hope you can get it back in the air again soon.
