RE: Anyone for BIPE cutting?
i have a 1/5 pica waco that has a split fuse, i did have to add quite a bit of lead to the nose to balance. uses 2 long balsa planks (1x3/4) to add stiffness with 3 bolts to attach. servos mounted under the cockpit on a plate that stays with the rear half.
