RCU Forums - View Single Post - Help with HOB 2X4 sailplane and E-power
Old 08-30-2007 | 02:04 PM
Bluesun9
Default RE: Help with HOB 2X4 sailplane and E-power
Thanks Bob;
I think I shall try the nose mount GWS 400. I have the fuse built with the stock lite ply. Might try drilling some holes in the side to reduce the weight factor. Had even considered a OS .15 on the front with a lite landing gear as a tail dragger for TOG. I might be pushing this little bird hard. I do like the way you have yours set up. HOB says I can use standard size servos but I have installed the H-55's because of the weight factor again. I thank you for your help and if you could post some pics of the servo and battery compartment I sure would be interested in seeing them and just how you did that part.
