RCU Forums - View Single Post - Showtime
Thread: Showtime
Old 08-31-2007 | 12:54 AM
  #2111
ILVSMOG
Default RE: Showtime
Just got done working my way through this thread (over the course of a few days!!) and there's a ton of info here!! I'm just getting ready to build my Showtime and wanted to run my setup past you all to make sure I haven't overlooked anything.
I'm using the Saito 125 on a Hyde mount. Hitec 5625s and a 5645 in the rudder set up for pull-pull.
I'm planning on using Robart hinges so as to avoid the CA failure issue, but I'm not 100% sure which size to use. I'm thinking 1/8" but do any of you have any other suggestions?? Also, do I need to run some sort of fuel pump or tank pressurization device with this motor if I set the tank back to center of CG?? I've seen and heard mention of the Cline and Perry parts, but I'm not real sure what they do or how they do it.
If there's anything else I've overlooked, please let me know and THANKS!!!!
