RCU Forums - View Single Post - Quick Question
Old 08-31-2007 | 11:44 PM
jdetray's Avatar
jdetray
Default RE: Quick Question
The surging is your ESC detecting that the battery voltage has dropped below the low voltage cutoff (LVC) point. You also mention that the motor is getting hot.
These two things tell you that you are drawing too much current.
With that high kV motor and that big prop, this is not surprising! You need to either prop down, get a lower kV motor, or put the motor in a gearbox. A motor with such a high kV is not intended to be used in direct drive, unless it's with a real small prop.
At 139°F, you may be close to permanently damaging the magnets in your motor. It depends on the magnet material. Once overheated to the point of damage, the magnets will never recover, and the motor will draw more current than ever, so it's a downhill spiral.
As for the battery, you'll eventually damage it with that setup. So both your motor and battery are at risk.
You need a wattmeter to know for sure what is happening, but it's safe to say that you're using much too large a prop for that motor.
- Jeff
