Well with clearer eyes this am and ferther inspection, you were right the one way berring was slipping, but I also found that the sleeve on the shaft had moved out about 3/16, and that is just enough to let the end roolers not to make contact with the sleeve. Resetting the sleeve with new loc-tite is no problem, but should I put a nut on the shaft?? If so what is the size and thread??
Hay Jim
One old G-38 is enough
But thanks for the offer
Bob T
