Offset = (Firewall to prop drive distance) X sin(angle of right thrust).
Crtmmac,
You really solved my problem! Thank you so much!! Quedstion now is: angle is -2 degrees... After applying the formula, I've got a negative number, which is -5xx mm. Is it to the left or to the right?
Thanks!
Flavio
