its similar to the xlb than the mammoth st or the st pro. the truck was broken in today and it drives like its on rails, i put in diff oil front and rear and changed the shock oil and did some minor work to the throttle and brake linkages. this thing rips the ony thing that broke was the body posts when it landed up side down. i knew it would happen it always does when you have screws holding them in and not clips ,thats the next thing i am going to fix. the steering servos worked flawlessly ,i even held the front end down to the ground and it still turned the tires unheard of in the monster truck world. it has a place for the bump start , and i can install the center diff in and race at the track. this has more than enough power just in first gear when second hits there is no controlling it, this is trully as the saying goes a bat out of he..saitan land
. this is the sleeper truggy everyone has been waiting for.
xtm i think got it right this time and listened to the people and they sure out did themself with this truck. the motor was a piece of cake to breakin and after the mt did its thing. the only thing i changed were the throttle linkages and brake because they hit each other and a few extra parts i put on check out the pic see if you can tell cen owners
