RCU Forums - View Single Post - Incidence setting ?
Old 09-01-2007 | 09:00 PM
  #38
Geardaddys
Default RE: Incidence setting ?
Dign',
These guys all have it right.. you shouldn't need an incidence meter with this airplane.. I built one a few years ago. It was actually my first build (probably a little over my head at times) but turned out pretty good.. I did use an incidence meter to check the wings after all was done to make sure I hadn't built in any warps.. Anyway, what motor setup are you going to use with this plane? I used the suggested geared t600 setup and was VERY displeased with the power output of this setup.. Mine wouldn't do a rolling takeoff from short grass to save it's life. Anyway, took all that out a few months ago and put in a great planes rimfire outrunner, lipo and associated ESC.. Cut 10 ounces of wt, and doubled the thrust.. Now it's a SuperCub!
John
