RCU Forums - View Single Post - super skybolt engine ?
Old 09-01-2007 | 10:49 PM
opjose's Avatar
opjose
Default RE: super skybolt engine ?
ORIGINAL: da Rock
As for your maybe being just too lean. Good possibility.
Yes. As he said.
You can "overload" an engine and merely have it sag, but not overheat if it is properly tuned, but not quite prop'd properly.
On a different plane we found my GMS .76 had it's head temp rising to 400 degrees!!! I was fighting to get it in tune.
I remembered that someone here posted that the head temps should be around 290 degrees F.
I richened the engine out to the point that the temp dropped to about that, and my troubles were gone.
It still seemed a bit rich to me on the ground, but this proved perfect in the air.
I was running a large prop too...
