RCU Forums - View Single Post - Brison 5.8 best performance
Old 09-02-2007 | 08:28 AM
Thunder8A36
Default RE: Brison 5.8 best performance
At first lok and checking, the teflon ring that hold the sensor is blocked with a set screw wich is in the spot already drilled from factory, but you could be rigth, let me to install a degree wheel and have numbers in my hand.
But how much are the max rpms alouded for this engine Pat?
DP
