RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 09-02-2007 | 08:50 AM
  #6083
Flyer95
Default RE: U-Can-Do 3d 46?
ORIGINAL: AKFireMedic
I still have a bad radio glitch, hit issue that I can't seem to cure. I re-routed my antenna inside an antenna tube to see if that helps. For whatever reason I can't duplicate the issue on the ground, only once the plane is in the air...and my shorts are wet from wondering if I'll get her down in one piece again! Very frustrating...[:@]
The glitch can be caused by loose and vibrating metall parts. The glow fourstroke engines in it self can not cause radio interference but if you are by accident using a onboard glow driver and the contact is bad or loose it will cause radio noise.
If this is not the case then most probably the glitching servo is bad, try another one.
