RE: Polk's Hobbies radios?
Hi I just got back from the field...........I lost yet another plane with the same symptoms.........no in put on all surfaces.
The first one I lost, I thought that the only thing it could have been was the batt. connection. There was nothing wrong with the battery the controls or switch harness.
The second plane (today) had all fresh gear in it Ie: new switch, new 1100 mah batt. Futaba reciever, and I had the radio sent for service check out after the first crash.
Same thing! Slow high split s.........at the bottom..nothing...pullback on elevator nothing.....cut the throtle,nothing.........I even had time to try a wing wiggel with the ailerons nothing.
Plane did hit the ground though. Thats something.
