RE: HELP!! WOBBLE PROBLEM!!!!
I have found that the replacement blades are thinner and more flimsy. If you lock down the heli in a vice or heavy weight and then do your spool up slowly you will notice at eye level that the blades will flex at different RPM's. If the blades flex up from center to outter edge you will lose your lift plus pick up vibrations.
