RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 09-02-2007 | 10:50 PM
  #6086
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
AKFireMedic,
On "Do" #1 Hi tec radio gear running a YS-63 and then S-100 I had no
glitch problems.... On "Do" #2, S-82 Same radio gear in the same location, and
the ant. wire ran out the bottom of the fuse to the tail as before I also tried taping
the wire to the top of the fuse.. I have had a glitch problem from the onset...
I have check all even went so far as replacing reciever, servos and wires with
no change.. I did have sull. tail wires, but that was modified and finally removed
and I still had an intermitent glitch.. I was going to try the glitch buster<??> but
I ended up just taping my ant. wire to the bottom of my left wing with scotch tape
which I still do, no more glitch problems
