RCU Forums - View Single Post - E-starter Assembly?
Old 09-02-2007 | 11:34 PM
Time Pilot's Avatar
Time Pilot
Default RE: E-starter Assembly?
Does the stick still slide into the hole? Usually the stick can be pushed in further so you don't have to cut it. Whatever you do, make sure there is enough stick in the hole or it will break loose.
On page 14, there is a diagram that tells you where the CG is. It's just behind the wing spar. There is actually a CG molding mark underneath the wing.
