RE: Seagull Ultimate
The pull/pull is correct. All the book says is 6 digital servos. I used Futaba 70oz digitals on the aile. I used 2 stock Futabas on the elev. Each elev half has it's own servo mounted inboard. I used a 3305 Futaba on the rudder. It is a 99oz metal gear. And a stock servo for the throttle.
One of the things I like about this plane is you don't see all the servos sticking out of the tail.
The aile servos do stick out of the wing but they are on the bottom.
Ask if you need anything else, David
