RE: Percentage of Nitro in the Fuel
high nitro will increas the fuel usage probably increas the rpm somewhat and theroreticly cool the engine but you should add a bit of oil note if you use alot of nitro watch for a lean run motor wont last 3 flights if your really lean...
