RE: Aviation Models/TOC 30% Extra 260 BUILD THREAD
After I put a thick washer under each bottom mount I got 2 degrees of up thrust in relation to the angle of incidence which was set at 0. When I measured from the back of the thrust plate to the cowl it was equal top to bottom after the mod.
