RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 09-03-2007 | 08:02 PM
  #4163
crashcrash
Default RE: Wheeeeeeee.......... Blade CP!
Stock transmitter habits: In what I thought was glitching sudden jerks to the right and forward on many occasions...it was NOT RF interference as I originally thought. Further dinking around I discovered that the problem was in the TX it's self. In addition to the jerking forward and to the right.....the throttle side also has a "glitch" where you completely loose throttle and the motor cuts out momentarily (dead spot in the POT). The pots in the stock TX for whatever reason get "dead spots" or a build up of crap in them causing havoc in the heli. Right now...for now, NO glitching is happening because I cleaned the pots (drown them with contact cleaner), and the problems go away. It's nothing more than "you get what you pay for" going on here. If you replace all the gimbal pots with better quality pots....the problems will go away completely. I've had 3 stock Tx's do this on me yet Futaba nor the DX6 have ever glitched like that. If you experience a hard jerking to the right/forward (makes sense), or your throttle has momentary cutouts....that's what's going on.
