RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 09-03-2007 | 08:59 PM
  #4165
crashcrash
Default RE: Wheeeeeeee.......... Blade CP!
ORIGINAL: theradioflyer
That makes a lot of good sense Crash. When I get a glitch my heli shoots strait down, no left, right, forward or back. I'm not sure if the motor slows but the pitch takes a nose dive. I've done a lot to the heli to makes sure the ant doesn't have problems, as far as the trans: nothing. I noticed when my batts in the trans got low I had more problems.
Right on and thanks Vic[8D]
God bless B.O.B.'s
Since pitch is directly associated with the throttle (and I've noticed the same thing as you but slightly), that the pots for the throttle are causing it. YES...low batteries are a BAD thing...it can actually ruin the TX. When I have two green LED's out.....I quit flying and go charge it up (yes, I made mine re-chargeable...saves money/time/space). The DX6 and Futaba aren't bullet proof from failure BUT...they are made with better quality components reducing the incidents of failure.
