Originally posted by Kevin_W
The problem I had/have is that I am using the retract channel to control gain (two position switch) and without reversing the servo (or changing the mounting and linkage) the gain would only go the the side with AVCS (HH) with the gear in the down position.
For others out there, Horst Lenerz's electronic retract valve is handy is this application, use the gear channel to set the gyro gain, and then you program the retract valve, both direction and pulse width, independantly.
