RE: Best building glue
I use Titebond for most joints, except for those that need to be glued after the parts are positioned, then I use CA. I also try to use Titebond on joints that are going to be covered since CA is much harder than balsa and it's hard to get a smooth joint when sanding. Don't use thin CA on plywood, only medium or thick. You also need epoxy for the firewall.
