RCU Forums - View Single Post - which battery is better?
Old 09-04-2007 | 06:06 AM
jetmech05
Default RE: which battery is better?
I'm not much on electric systems for your application,,,but if the voltage is the same..the polarity is the same.then its good to go..the MAH rating just gives you an idea on the life of the battery depending on load. ie 2200mah you can draw 2200ma for an hour or 1ma for 2200 hours. hope I helped you out
